rads pinholing
hi, i work for a local council and we have a house thats had nothing but trouble with rads for the past 3 years. The boiler was changed late 2005 and since then the system has had 12 new rads! Some have only been replaced approx 5-6 months and they pin hole again, The system has had 4 powerflushes by 3 different companies, one even took all the rads off flushed individualy and then flushed the whole system. Its allways been protected using good inhibitor, think they have been using sentinal. Its even been double dosed. The rads still keep corroding and bursting. The tenent has said hes never had any running problems, it dosnt drag in air and hardly ever needs bleeding. ive looked over the system and cant find anything that would cause it apart from the system is allways sludged up even after 4 powerflushes, i have asked the tenent if he has seen the guys testing the dump water when powerflushing to make sure all the acid has been nutralised but he couldnt remember. Just woundered if any of you could shed some light on this as the tenent is elderly and getting very frustrated. thanks
