Results 1 to 11 of 11
Plumbing & Plumbers Forum - optima 701 DHW problem
Discuss optima 701 DHW problem in the Central Heating Forum at Plumbers Forums; Hi my hot water stoped working yesterday il describe what happens Nothing when you open the hot water tap not a sound comes from the boiler no clicks or anything.Central ...-
31-05-2010 #1New to Plumbing Forum
- May 2010
- 6
Nothing when you open the hot water tap not a sound comes from the boiler no clicks or anything.Central heating works fine.
so today i decided to join the forum to see if i can get any help but before i did i downloaded the Manual and noticed the fault finding LEDs were fine no faults were showing so i decided to press the reset button on the clock and run the heating for 30 mins and the hot water decided to work it seems fine now working as it should but am pretty sure this wasnt a one off so need some advice if it happens again
many thanks
31-05-2010 #2uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,341
- 827
- Thanked 1,266 Times in 1,209 Posts
Re: optima 701 DHW problem
could be a thermistor fault
GASMAN
31-05-2010 #3New to Plumbing Forum
- May 2010
- 6
ok great many thanks i shall order one just incase
thanks again
31-05-2010 #4Top Plumbing Forum Contributor
- Apr 2010
- 838
- Thanked 33 Times in 32 Posts
IT sounds like a dhw flow switch fault but i can't for the life of me remember if the optimas have a flow switch. If no flow switch then I'd say sensor also
31-05-2010 #5New to Plumbing Forum
- May 2010
- 6
Hi there is a Flowmeter acording to the manual and i will paste a section here of the only mention of a flow switch
The pump circuit also has a 6 minute over-runfor Domestic Hot Water"
time. There is a Domestic Hot Water flow switch fitted and when there is a demand for Domestic Hot
Water the Central Heating pump is switched off making available the maximum output of the gas burner
31-05-2010 #6Top Plumbing Forum Contributor
- Apr 2010
- 838
there u go mate. It'll be this flow switch, it won't recognise that you are running a tap obviously if it's goosed, it's the same as not running hot water if it was working correctly as far as it's concerned at the min, therefore no fault code will show for this particular fault
if u are able to link out the flow switch and the boiler fires for hw then it's defo at fault. This is the easiest way to prove a faulty component
One last thing to add.
U could try removing it and clean it. U may find it's not faulty and simply choked upLast edited by Mbear; 31-05-2010 at 06:50 PM. Reason: Automerged Doublepost
31-05-2010 #7New to Plumbing Forum
- May 2010
- 6
hi any idea were it is? my problem is in the manual the only part listed sith the word switch is
Low water pressure switch
is this it?
many thanks
31-05-2010 #8Top Plumbing Forum Contributor
- Apr 2010
- 838
31-05-2010 #9New to Plumbing Forum
- May 2010
- 6
Hi sorry all i can see on the diagram is a flowmeter
31-05-2010 #10Top Plumbing Forum Contributor
- Apr 2010
- 838
31-05-2010 #11New to Plumbing Forum
- May 2010
- 6
nice one i will strip it tomorrow failing that its only £38 to replace
CWSC overflow problem
By pg1066 in forum Plumbing ForumReplies: 8Last Post: 19-05-2010, 12:21 AM -
baxi 105e dhw problem
By bryan in forum Central Heating ForumReplies: 5Last Post: 14-04-2010, 02:28 PM -
ferrolli optima 701
By metalmick in forum Central Heating ForumReplies: 3Last Post: 22-03-2010, 07:14 PM -
Potterton 30HE DHW cut out problem
By pebrey in forum Central Heating ForumReplies: 4Last Post: 12-12-2009, 10:18 PM -
MicroGenus 23 DHW problem
By Nigel 206 in forum Plumbing ForumReplies: 0Last Post: 15-03-2009, 01:21 PM
Cost to remove old electric...
8 Minutes Ago in Plumbing Forum
