Results 1 to 4 of 4
Plumbing & Plumbers Forum - Ideal Classic NF80 problem
Discuss Ideal Classic NF80 problem in the Central Heating Forum at Plumbers Forums; I have been called out to service an Idel Classic NF 80 boiler wich was not working. When I undone the control box so that it was hanging on its ...-
26-05-2010 #1jnwGuest
hanging on its wiring the boiler started up as it should. so I put the contol
box back in position and then nothing so undone the control box again as
before and the boiler stated working again. So I checcked all the connections and all the wires for continuity and all seems fine but when I
Screw the control box back the boiler fails to start. I have been in contact with technical support and they say it must be a loose connection but I still have not found one. Has anybody had a problem like
this or any idea what it could be.
Thanks Jeff
26-05-2010 #2Plumbers Arms member
- May 2009
- 7,303
- 218
Re: Ideal Classic NF80 problem
Well if you can not find a loose connection ,it is probably a dry joint on the pcb,remove pcb board and resolder main connection points and relays
Some would say just replace pcb
26-05-2010 #3Top Plumbing Forum Contributor
- Apr 2010
- 838
- Thanked 33 Times in 32 Posts
27-05-2010 #4jnwGuest
Thanks for that I will give it a go
Ideal classic mystery
By Jackbooted in forum Plumbing ForumReplies: 3Last Post: 25-03-2013, 06:44 PM -
HELP! Ideal mini C-24 hot water problem
By alexz in forum Central Heating ForumReplies: 0Last Post: 06-02-2010, 03:33 PM -
Ideal Classic Boiler problem
By GEOFF BRADBURY in forum Plumbing ForumReplies: 1Last Post: 10-01-2010, 10:52 PM -
Ideal Isar boiler problem
By Chappers in forum Central Heating ForumReplies: 2Last Post: 08-01-2010, 06:40 PM -
Ideal Elan 2 boiler problem
By eamdp03 in forum Central Heating ForumReplies: 13Last Post: 19-12-2009, 09:22 AM
ACS exams
4 Minutes Ago in Gas Safe Register Forum - Public Forum
