Results 1 to 10 of 10
Plumbing & Plumbers Forum - Radiators getting hot when hot water tap is run
Discuss Radiators getting hot when hot water tap is run at UK Plumbers Forums; Maybe it's todays blistering heat that's making me finally ask about this. As the post title says, all of the radiators (upstairs and downstairs) in my house get hot (fully ...
    whiterz
    Thumbs down Radiators getting hot when hot water tap is run
    As the post title says, all of the radiators (upstairs and downstairs) in my house get hot (fully hot!) when the hot water tap is run. The longer the tap is run for the hotter they get, but it never takes too long to get them steaming.
    I just want to say that where plumbing is concerned I know next to nothing... so its hard for me to supply any relevant details without being prompted first. However I guess the make of my boiler might be useful to someone? It's a BAXI Combi 105e.
    If someone could give me some kind of idea of whats going on? I'm certainly no expert but it seems extremely abnormal to me! .
    Thanks! - whiterz
    (p.s. Hi everyone, I'm new here)
    838
    Default Re: Radiators getting hot when hot water tap is run
    My first guess would be the diverter valve gubbings aren't moving properly in hot water demand, probably due to dirt choking it up.
    Fix....
    Remove gubbings and clean or just replace gubbings.
    also fit magnaclean to protect from future choking
    whiterz
    Quote Originally Posted by Mbear View Post
    Fix....
    Ahhh that sounds like a pretty good guess to me because we had alot of problems with the build up of iron oxide sludge in the past. Thanks .
    Would the whole system have to be drained and flushed out (i.e. radiators taken off the walls and washed out etc.) prior to fitting a Magnaclean or would the Magnaclean be sufficient by itself?
    838
    I don't know if I can comment without seeing it mate, once the dv gubbings are replaced you'll have a better idea when you see the condition of it.
    But powerflush and magna sounds like it would really help you.
    magnafilter will be sufficent after it's been flushed
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,737
    classic knackered divertor valve
    whiterz
    Purfeck. Thanks guys that's all I needed to know
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,737
    Quote Originally Posted by whiterz View Post
    you would need a full descale rads off etc
    Nov 2009
    525
    Magna clean is an 'as well as' a flush, not 'instead of', unfortunately your system can be flushed but not a combi with diverter valve, could damage it.
    oldplumber
    Fix....
    bet your popular with the parts center counter staff, asking for a gubbings on a busy monday morning
    838
    Quote Originally Posted by oldplumber View Post
    sorry that's just what I call it when talking about these kinda bits with boys in work Hehe! I'm pretty sure it's the alpha 710 seal kit that u would buy for this dv. I'm positive baxi don't do such a kit. The alpha kit fits it.
  1. Radiators still running water
    By Fontanero in forum Plumbing Forum
    Last Post: 26-09-2013, 06:46 PM
  2. radiators ok,but only hot water when ch is set to off
    By brucieboy in forum Central Heating Forum
    Last Post: 23-01-2013, 06:56 PM
  3. No Hot water, Radiators fine - Diverter?
    By toma80 in forum Central Heating Forum
    Last Post: 20-11-2012, 01:58 PM
  4. No hot water/Hot radiators
    By camerart in forum Central Heating Forum
    Last Post: 17-06-2012, 05:51 PM
  5. No hot water unless radiators on
    By chemistpm in forum Central Heating Forum
    Last Post: 05-06-2012, 06:27 PM
  6. No hot water but Radiators OK
    By malcmw in forum Central Heating Forum
    Last Post: 11-01-2012, 05:12 PM
  7. Draining and hot water system via radiators
    By jiffter in forum Plumbing Forum
    Last Post: 15-03-2011, 11:05 PM
  8. Can't put hot water on without putting radiators on.
    By nelster in forum Central Heating Forum
    Last Post: 26-10-2009, 07:57 PM
  9. Radiators getting hot, but no hot water
    By Ruggy1980 in forum Central Heating Forum
    Last Post: 20-05-2009, 10:12 PM
radiators get hot when running hot water
why do my radiators get hot when i run hot water
radiators get hot when hot water on combi
radiators get hot when running bath
radiators getting hot when hot water on combi boiler
