Results 1 to 12 of 22
Plumbing & Plumbers Forum - temporary electric shower.
Discuss temporary electric shower. at UK Plumbers Forums; my boiler isnt arriving until the 17 th so i am considering a temporary electric shower for the time being. is it possible to connect a longer cable to it ...
    Jun 2009
    188
    Default temporary electric shower.
    is it possible to connect a longer cable to it , run this into the next room then put a standard 3 amp plug onto it? i know its not ideal , my ring main is rcd protected and the mbc is rated at 20 amps.
    what do you guys think ?
    Aug 2008
    57
    Default Re: temporary electric shower.
    No. what is the kw rating of the shower
    Jun 2009
    188
    10.5 kw i think , its defo 10 something. why not? the socket and plug will be well away from any bathroom zones , in the next room.as far as i know it has to be on a switched power supply so isnt a plug socket a switched power supply?
    oldplumber
    why not put this question to an electrical forum for a sensible answer because youve got to be taking the ++++ asking such a question here!!!!
    Jun 2009
    188
    why do you think im taking the ****? i am actually being quite serious. my boiler is now going to arrive on the 17th instead of this monday ,because of this the electrician isnt coming to do the bathroom electrics until the 19th , still not sure when the plumber is coming to do the boiler (he was going to do it tuesday) and i have a new born baby due on the 23rd so yes , i am very serious. i need to put in a temporary shower until i get the boiler and electrics in.
    oldplumber
    10.5 kw =10500watts aps x volts = watts therefore watts/volts = amps.
    10500/240 = 43.75 amps, so is your 3amp fuse going to work. next question how are you going to wire in 10mm twin and earth cable into a 13 amp plug, 10mm cable being the minimum size youll probably need to power a 10.5kw shower.
    May have got a couple of things wrong, but not likely so hence my question are you taking the p*ss? Hindsights a great thing but you need to get your project management upto scratch and quickly by the look of things, why not send the missus and baby to the in laws, cos your solution is positively stupid and dangerous.
    migoplumber's Avatar
    blackpool
    2,138
    STOP SWEARING.
    the question is valid for somebody who does not understand.
    NO it cant be done. and as said above positively dangerous to try.
    Shaun, GS 233006, Engineer 2485197
    oldplumber
    can you publish a list of the swearwords we can and cant use please, +*** wasnt a word i would consider swearing normally, is wee wee acceptable as in "are you taking the wee wee". Thanks in advance
    blackpool
    2,138
    yep wee wee is totally acceptable old plumber, please use that in the future.
    many thanks
    oldplumber
    thanks again, I do so like a sense of humour in our moderators,
    Jun 2009
    188
    Quote Originally Posted by oldplumber View Post
    May have got a couple of things wrong, but not likely so hence my question are you taking the ++++? Hindsights a great thing but you need to get your project management upto scratch and quickly by the look of things, why not send the missus and baby to the in laws, cos your solution is positively stupid and dangerous.
    now thats the answer i was looking for , thank you. so it looks like i have a problem. so is wiring a shower within the realms of a plumbers expertise or should i take your advice and ask an electrician?
    oldplumber
    what for, project managment?
  1. My temporary wheels
    By kirkgas in forum General Off-Topic Chat
    Last Post: 03-08-2013, 06:34 PM
  2. Electric shower + electric water heater
    By gijno in forum Plumbing Forum
    Last Post: 25-02-2013, 11:59 PM
  3. Replies: 21
    Last Post: 07-11-2012, 10:12 PM
  4. Temporary fix to wc bowl
    By scotty plumber in forum Plumbing Forum
    Last Post: 28-05-2012, 10:08 PM
  5. Replies: 6
    Last Post: 19-05-2012, 10:59 PM
  6. Replies: 6
    Last Post: 13-02-2011, 07:10 PM
  7. temporary bonding
    By adrianfs1 in forum Plumbing Forum
    Last Post: 02-02-2010, 10:41 PM
  8. removing power shower / installing electric shower - need help please
    By alacn in forum Bathrooms, Showers and Wetrooms
    Last Post: 28-08-2009, 08:45 PM
  9. Replies: 3
    Last Post: 26-08-2009, 02:08 PM
  10. Bath tap not very hot.
    By ZedTheRed in forum Central Heating Forum
    Last Post: 07-04-2009, 09:49 AM
plug in shower
plug in electric shower
13a electric shower
13 amp power shower
