Results 1 to 9 of 9
Plumbing & Plumbers Forum - Centrifugal extractor fan choice
Discuss Centrifugal extractor fan choice at UK Plumbers Forums; Does anyone have experience of the Vent Axia Solo Plus or Quadra range? I need a bathroom extractor for a relatively long extraction run. The Quadra seems more powerful on ...
    Dec 2016
    11
    Default Centrifugal extractor fan choice
    Does anyone have experience of the Vent Axia Solo Plus or Quadra range? I need a bathroom extractor for a relatively long extraction run. The Quadra seems more powerful on paper but also more noisy?
    Is it worth going for the Humidstat version for a bathroom with no windows or just a timer with an overrun?
    10,005
    Default Re: Centrifugal extractor fan choice
    If it's a long run why not use an inline fan ?
    Chalked's Avatar
    3,928
    Humidistat are the best, as it will run on until the moisture is lowered. Go for the best you can afford, with the best flow. All are noisey to some extent. If you can get an inline fan amd fit it to a somthing solid. This will keep the noise down.
    Dec 2016
    11
    Can't break the ceiling for an inline fan so has to be a surface mounted centrifugal but not mega noisy as the bathroom is off the bedroom.
    10,005
    Quote Originally Posted by ArchieC View Post
    So your mounting it to the wall and cutting a hole through ??
    Dec 2016
    11
    No it will be ceiling mounted.
    10,005
    how as you said you cant drill the ceiling ?
    Dec 2016
    11
    I said I can't break the ceiling (as it has already been finished) so the fan will be surface mounted. The wire is there as is the ducting.
    west midlands
    1,395
    Sadly ceiling destined to be a sound board , need access to pipework and stick it in-line !
  1. Syphonic Air Extractor
    By blanco in forum Plumbing Forum
    Last Post: 04-07-2012, 01:41 PM
  2. Best extractor fan for bathroom??
    By Mobrown in forum Plumbing Forum
    Last Post: 10-06-2012, 12:04 PM
  3. which bathroom extractor fan?
    By gt67 in forum Bathrooms, Showers and Wetrooms
    Last Post: 14-12-2008, 03:27 PM
