Results 1 to 10 of 10
Plumbing & Plumbers Forum - Advice on best solution for pump for 2 showers
Like Tree4Likes
  • 1 Post By johnf
  • 2 Post By Plumbstar Tom
  • 1 Post By Plumbstar Tom
Discuss Advice on best solution for pump for 2 showers at UK Plumbers Forums; Hi, I currently have one pumped shower and one gravity fed. I want to add a pump to that one too. Is it best to have 2 separate shower pumps ...
    61
    Default Advice on best solution for pump for 2 showers
    I currently have one pumped shower and one gravity fed. I want to add a pump to that one too. Is it best to have 2 separate shower pumps or a new 3.0 bar pump that can run both showers?
    The current pump has a direct 15mm feed from the cold water tank in the loft and a 15mm feed from the top of the hot water cylinder. It would be good if I could re-use these pipes for both showers however I wonder if they need to be 22mm if Im going to run 2 showers at once. so in short
    1) Can a 15mm feed to a single 3.0 bar pump run to showers?
    2) If not should I swicth this to 22mm OR just install a speate pump and new hot and cold feeds?
    Marc
    Somewhere in the South West
    110
    Default Re: Advice on best solution for pump for 2 showers
    Hi Marc
    15mm cold feed should not be used for a cold feed for one pump let alone two. Stuart Turner pumps have a good technical team and if you give them a call they can advise you well on this.
    Masood likes this.
  3. The Following User Says Thank You to johnf For This Useful Post:
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    3,670
    I think you would have to consider increasing your cistern size too. two power showers use water up very quickly
    johnf and Masood like this.
    Regards
    Tom
  5. The Following User Says Thank You to Plumbstar Tom For This Useful Post:
  6. #4
    61
    OK thanks - I read that about the cistern size however we have the same amount of showers now, just one after each other so dont think it will be a massive problem.
  7. #5
    Jul 2009
    Staffordshire
    3,670
    yes but one is gravity fed and now it will be a power shower so it will be using water a lot quicker. If you run that pump dry it could write it off
    Masood likes this.
    Regards
    Tom
  8. #6
    61
    ok thanks
  9. #7
    61
    i mean we only use the power shower now but have 3 showers in a row but there is enough hot water
  10. #8
    Aug 2014
    661
    Yes but your CWT supplies hot and cold to the shower. What size is the current tank?
  11. #9
    61
    50 gallon
  12. #10
    Aug 2014
    661
    Double up on cold water storage.
  1. Slow starting shower pump solution !
    By Jules in forum Plumbing Forum
    Last Post: 29-04-2015, 04:15 PM
  2. Double p trap question or AAV solution? Advice required.
    By Bobberdiddly in forum Plumbing Forum
    Last Post: 20-01-2015, 12:20 AM
  3. Shower pump to feed 2 showers - advice needed
    By smox in forum Bathrooms, Showers and Wetrooms
    Last Post: 27-11-2014, 08:33 AM
  4. 1 pump, 2 showers
    By MP plumb in forum Plumbing Forum
    Last Post: 24-02-2013, 04:20 PM
  5. Replies: 15
    Last Post: 16-02-2013, 01:34 PM
