Plumbing & Plumbers Forum - Shower upstand hydrohalt
Discuss Shower upstand hydrohalt at UK Plumbers Forums; Hello all I have seen that there are mixed views on fle flexible stick on upstands,however my tray is eastbrook and their instructions recommend the use of this type of ...
    Dec 2016
    15
    Default Shower upstand hydrohalt
    Hello all
    I have seen that there are mixed views on fle flexible stick on upstands,however my tray is eastbrook and their instructions recommend the use of this type of upstand and as such i purcased a product called sealux aquastrap, i then went on line to look at the instructions as i am not using tiles but splashwall pvc cladding, while on the sealux web site i noticed a product called hydrohalt ,it is the manufacturers new all singing product from a couple of years ago,i spoke to them and they told me it was a far superior product to there standard stick on upstands but then they would say that wouldent they, i did however purchase one and it is a kit that contains a kind of flexible tanking strip that is bonded to the wall and then a foam spacer and finally all bonded together with sealux silicone.has anybody seen or used hydrohalt as i cant find any reviews on it.i now have two upstand types and not sure which to use.
    Any opinions. Many thanks.
    Aug 2016
    Default Re: Shower upstand hydrohalt
    I am late on this but, Aquastrap and Hydrohalt are both Sealux products, if you are installing PVC shower wall panels have you considered using Cladseal which conceals the silicone completely and eliminates maintenance.
  3. The Following User Says Thank You to Plumbex For This Useful Post:
    Dec 2016
    15
    yes i did take a look at cladseal but dont like the look of a plastic profile,they still are reliant upon a silicone bond to the tray which to be honest i just dont trust,if it does eventually fail then you cant get at it as the bond is under the cladseal and just because its hidden dont mean it cant fail,the silicone is still subject to movement expansion,contraction, shrinkage etc. i much prefer a well done silicone bead then if you get problems scrape it out and do it again.
    for anybody reading this thread i went with aquastrap then panels over aquastrap down to spacers on top of tray to leave a 4mm gap then silicone filled the gap and nice finish with fugi tool. dident go with hydrohalt as again it looks a quality sealing system but still relies on a silicone bond to the tray, the butyle rubber and adhesive just looks more substantial on the aquastrap.time will now tell.
    thanks for all the responses.
  1. Thermostatic triple diverter shower valve with body jets and shower rail set
    By fletcher7751 in forum Bathrooms, Showers and Wetrooms
    Last Post: 07-01-2017, 11:29 AM
  2. Running costs of electric shower vs normal shower from immersion / hot water tank
    By Spurano in forum Bathrooms, Showers and Wetrooms
    Last Post: 02-10-2015, 01:44 PM
  3. Replies: 0
    Last Post: 18-08-2014, 03:13 PM
  4. Replies: 0
    Last Post: 18-08-2014, 10:53 AM
  5. Replies: 1
    Last Post: 08-05-2010, 12:55 AM
