Results 1 to 4 of 4
Plumbing & Plumbers Forum - Easyplumb shower tray install
  • 1 Post By townfanjon
Discuss Easyplumb shower tray install at UK Plumbers Forums; Good evening all. Currently fitting a 800x1000 offset quadrant tray on easy plumb legs, i was thinking of fixing battons to the wall below the tray to contact the edge ...
    Dec 2016
    15
    Default Easyplumb shower tray install
    Good evening all.
    Currently fitting a 800x1000 offset quadrant tray on easy plumb legs, i was thinking of fixing battons to the wall below the tray to contact the edge of the stone resin tray the same as for a bath tub.is this worthwhile to give extra support or is it a big mistake and should i just use the easy plumb as it came, i would appreciate your opinions please.
    Also i propose to bond the tray to the wall so would like a good flexible adhesive and had proposet to use ct1 is this about the best or what do others use between wall and tray.
    Kind regards
    Ant.
    Dec 2013
    The center of the universe
    4,246
    Default Re: Easyplumb shower tray install
    Just use the legs pal , you dont need to use adhesive but when the tray is in place seal between the tray and wall with a good quality silicone ( if its fresh plaster pva it the day before ) . After you have tiled , seal it again between tiles and tray .
    AlexGas likes this.
  3. The Following User Says Thank You to townfanjon For This Useful Post:
    Dec 2016
    15
    I had thuoght there would be no need for extra support but wasent sure as i had seen some instructions on line for some random tray asking for a couple of battons to be fitted to the wall as well as the legs, i thought that sounded like a good idea but i suoopse i depends on the tray, mine is eastbrook and ii guess it may not be such an idea after all as should there be any movement and the wall battons picked up the weight the support on the legs could be lost and result in a cracked stone resin tray.
    What do you guys think.
    Regards ant.
    Aug 2014
    661
    The legs that screw or plug into the tray work well. I wouldn't use the system that has a ply board again.
  6. The Following User Says Thank You to Radioman For This Useful Post:
  1. Replies: 0
    Last Post: 31-12-2016, 10:47 AM
  2. Removing shower waste plug clamped to shower tray base
    By miketurner201 in forum Plumbing Forum
    Last Post: 18-08-2015, 08:46 PM
  3. What's best way to install a low profile shower tray so its waterproof
    By johnst in forum Bathrooms, Showers and Wetrooms
    Last Post: 14-08-2013, 09:44 AM
  4. Urgent Please help! How to install a shower tray
    By Bav3 in forum Bathrooms, Showers and Wetrooms
    Last Post: 12-08-2013, 08:41 AM
  5. Replies: 4
    Last Post: 29-05-2011, 04:14 PM
