Results 1 to 6 of 6
Plumbing & Plumbers Forum - What concealed thermostatic diverter, body jets, rain and hand held should l fit?
Discuss What concealed thermostatic diverter, body jets, rain and hand held should l fit? at UK Plumbers Forums; Hi all I will be fitting the above for a client, she had bought a set from an online specialist, see other thread, best thing they did was a refund! ...
    17
    Default What concealed thermostatic diverter, body jets, rain and hand held should l fit?
    Hi all
    I will be fitting the above for a client, she had bought a set from an online specialist, see other thread, best thing they did was a refund! Foreign HC inlet thread, valve faceplate could not be secured (relied on silicone), body jets had backnut which was inaccessible when tiled and instructions were poor.
    In your experiences, what manufacturers would you recommend on a budget of around £400?
    Pfister in USA look well made, but can't find UK stockist.
    Grohe are well reputed, but around three times budget
    Just need good quality, with instructions rather than a Krypton factor test, that can be fitted leak free and serviceable in use.
    Not much to ask.......
    Cheers
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    3,659
    Default Re: What concealed thermostatic diverter, body jets, rain and hand held should l fit?
    for what you want you need to go to one of the decent suppliers and for that reason i don't think you will get close to your budget
    Regards
    Tom
    17
    Thanks Tom
    The client thought it was a decent supplier, double the ebay cost, but you have no idea where it is sourced or their mark up. What do you think would be a ball park for that set up?
    Jul 2009
    Staffordshire
    3,659
    maybe around £600+
    Make sure they have decent water pressure for the body jets and they are plumbed in correctly, seen too many where all the water comes out the top two and dibbles out the others
    Also check how they want the diverter set up working, what controls what etc
    Regards
    Tom
    17
    Cheers Tom
    Pressure fine flow rate 18 l/m, so good too
    Got their requirements on controls, they never realised it would be rain and jets on one, hairwash on the other, and can't have all three on at once.
    Doing a 22 pressure loop to prevent last jet dribbles!
    Pfister in USA do a good range so you can pick and mix, good prices too....not here though.
    First thoughts were Grohe and Bristan, but the kits don't lend to bespoking a system, and Grohe costs are Bentley money!
    I'll keep looking, used to fit a lot of Pegler taps and TMV 2's will see what they offer.
    They were good quality, sturdy and spares were always there if needed.
    Would prefer to get separate components rather than a kit of misfits from god knows where.
    What would be your go to manufacturer supplier?
    Cheers
    Jul 2009
    Staffordshire
    3,659
    You can do what you want with decorative stop cocks and separate diverters if you want
    Regards
    Tom
  1. Thermostatic triple diverter shower valve with body jets and shower rail set
    By fletcher7751 in forum Bathrooms, Showers and Wetrooms
    Last Post: 2 Weeks Ago, 11:29 AM
  2. Body jets
    By E4gas in forum Plumbing Forum
    Last Post: 25-01-2015, 09:56 PM
  3. Hi all & quick Q re: body jets
    By Daz in forum New Member Introductions
    Last Post: 13-03-2011, 10:26 PM
  4. Body Jets advice
    By lump hammer in forum Plumbing Forum
    Last Post: 25-02-2011, 12:24 AM
