Plumbing & Plumbers Forum - Plastic Piping. tails to taps.... how to tell which brand
Discuss Plastic Piping. tails to taps.... how to tell which brand at UK Plumbers Forums; So, my last foray into plumbing was back in the days of copper pipe, gas torches and solder. t'other half has bought some shiny new bath taps and they're 'easy ...
    Jan 2017
    Default Plastic Piping. tails to taps.... how to tell which brand
    t'other half has bought some shiny new bath taps and they're 'easy to fit' *cough*.
    looking under the bath, theres two 15mm plastic pipes, which have been bodged by the previous owner onto some copper tails from the tap. Before I go down the road of sourcing new flexible tails with push fittings, how do you tell the difference in the pipes (eg is it speedfit or hep20?).
    Mar 2013
    1,449
    Default Re: Plastic Piping. tails to taps.... how to tell which brand
    Usually can see writing somewhere on pipe, but fittings are interchangeable,except inserts, that are best matched to pipe. Don't use inserts with external rubber seal under a compression fitting.
    Mar 2012
    Bolton
    2,097
    As above, the insert is the important bit, if the insert is a slightly tight fit then you're golden
    Get a few different brands of inserts from a merchants and see which one is the best fit. I know that JG inserts won't go in hep20 and hep20 inserts are too loose in JG. (Or it could be the other way round)
  1. Plastic piping for central heating
    By bassmonster in forum Central Heating Forum
    Last Post: 20-10-2015, 11:16 PM
  2. Piping unvented discharge in plastic
    By bogrodder in forum Plumbing Forum
    Last Post: 09-07-2015, 06:55 PM
  3. Plastic or Copper piping?
    By JoB333 in forum Plumbing Forum
    Last Post: 12-06-2015, 12:23 PM
  4. Plastic piping in solid flooring
    By Dezz in forum Central Heating Forum
    Last Post: 06-11-2011, 05:38 PM
  5. Plastic piping!
    By ALBEE in forum Plumbing Forum
    Last Post: 03-06-2011, 07:34 PM
