Results 1 to 12 of 17
Plumbing & Plumbers Forum - Thermostatic triple diverter shower valve with body jets and shower rail set
Like Tree2Likes
Discuss Thermostatic triple diverter shower valve with body jets and shower rail set at UK Plumbers Forums; Hi all, seasons greeting I have been volunteered to install the above, outside of my usual kitchens and bathrooms so seeking some advice There are three outlets, the rain head, ...
    17
    Default Thermostatic triple diverter shower valve with body jets and shower rail set
    There are three outlets, the rain head, hand held and three body jets to two facing walls.
    I understand that l can have two outlets on at one time, what is the usual way to plumb these in, there would have to be two of the above on at the same time - which two?
    Also there is no pipework or fittings to connect to any of the outlets, should this be in 22mm or 15mm, it is supplied by a new Ideal Logik.
    Any advice gratefully received, and a lesson on what you agree to whilst under the influence!!
    9,661
    Default Re: Thermostatic triple diverter shower valve with body jets and shower rail set
    What's your pressures and flow eg is the shower suitable for it
    And normally 15mm into the valve but you can if you want do 22mm as close as easily
    17
    Hi Shaun, thanks for reply
    As usual, client bough it as it looks good......
    Manuf say min pressure 1.5 bar and we are fine with that, will do a flow test, but they don't mention that in their sparse instructions
    All the connections to the valve body are 22mm incl the outlets
    I'll ask the client what they want, but l suspect wall jets on one outlet, and drencher and hand held on the other. .
    I am concerned that they will need a fire pump to operate them all though! I expect one outlet at a time in use.
    One of the walls with the body jets is an old hard brick wall, so happy days chasing ahead.
    At least one is a stud wall, that's where the valve body will be going!
    9,661
    Quote Originally Posted by fletcher7751 View Post
    If there 22mm pipe up in 22mm but confirm pressures and flow first
    17
    Will do, any idea on required flow rates?
    Ill check with VP....but don't hold out much hope there
    9,661
    Should say in instructions but aim for anything above 15lpm as anything less will be less than 7.5 lpm with two heads on
    17
    Cheers Shaun, will check that first
    Also would l need a pressure loop each side, as it's serving six body jets?
    jtsplumbing's Avatar
    Tavistock. Devon
    4,764
    Best of luck with it, another item purchased by customer, sounds like import rubbish, no proper instructions, Hope its WRAS approved ! check B4 you fit it, and if you do explain if it does not work it's down to them to sort it out,
    ShaunCorbs likes this.
    9,661
    Won't harm to connect them all together and to the valve twice
    17
    Its from Victoria Plum (no B!!)
    Don't know country of origin, wasn't cheap...., but instructions next to carsy paper!
    Will explain believe me, but first the flow test
    May end up fitting three body jets, they want three on opposing walls, but very concerned at supplying them all
    Thanks for all replies
    9,661
    Will be China
    jtsplumbing likes this.
    17
    Update - couldn't bring myself to struggle with no instructions, means of sealing and retaining either the body jets (has rear lock nuts!!!) or the valve faceplate other than silicone it the client agreed to return it. Now looking to get some proper kit, any suggestions? I am thinking a two way diverter for rain and 4 jets (not 6), and a separate hair shower on riser rail. That gives a working shower if either needs maintaining, and they will all be separately controlled.
    All suggestions of manufacturers greatly appreciated,
    Budget £400.
  1. Need some help with a Triple thermostatic shower mixer..
    By Richie_C in forum Bathrooms, Showers and Wetrooms
    Last Post: 27-09-2016, 12:23 PM
  2. Mixer Shower, inc body jets and waterfall shower head.
    By Unregistered in forum Bathrooms, Showers and Wetrooms
    Last Post: 26-02-2016, 03:48 PM
  3. Body jets / side shower design installation advice
    By woking in forum Bathrooms, Showers and Wetrooms
    Last Post: 30-07-2015, 12:56 PM
  4. Triple control thermostatic shower valve
    By too hot to hand in forum Plumbing Forum
    Last Post: 26-12-2012, 09:34 PM
