Page 2 of 2 FirstFirst 12
Results 13 to 24 of 24
Plumbing & Plumbers Forum - Pathetic water pressure from shower
Discuss Pathetic water pressure from shower at UK Plumbers Forums; Your best bet is to get someone round to do some tests on water pressure and flow. To be fair this should have been done before the new boiler was ...
  1. #13
    Somewhere in the South West
    110
    Default Re: Pathetic water pressure from shower
    Your best bet is to get someone round to do some tests on water pressure and flow. To be fair this should have been done before the new boiler was installed. Without knowing what you have at present and what you need it is hard to advise what is best for the situation. Stuart Turner and Salamander do a pump that you can add to the mains which will increase the flow to a maximum of 12lpm but this may not be the cause.
  2. The Following User Says Thank You to johnf For This Useful Post:
  3. #14
    Jan 2017
    12
    Who should I get to check pressure and flow, is that a plumber or water board job.
  4. #15
    110
    It should be done by a Plumber/heating engineer. Explain to them what you want doing before they come out as you want someone to do it properly.
  5. The Following User Says Thank You to johnf For This Useful Post:
  6. #16
    Jan 2017
    12
    I guess I can use my outside tap to measure my flow over a minute to see how much the homeboost would likely improve the flow.
  7. #17
    110
    Yes most of the time you can but not always. Your outside tap is likely to be fed from 15mm pipe. You may (although I doubt it from what you have said) have 22mm cold water main running after the stopcock and then Teeing off to each outlet. Check that there are no other obstructions such as service valves, check valves that can reduce flow.
  8. The Following User Says Thank You to johnf For This Useful Post:
  9. #18
    Jan 2017
    12
    As my shower is electric and fed from the cold water supply, is it not possible to just install a pump in the pipe running to the shower.
  10. #19
    110
    From the sounds of it, you are going to do this yourself. If you are then it can be more costly in the long run. You cannot put any old pump in. Unfortunate as it may sound you have to comply with the water regs which limit the about of water you can draw in off the mains. Have a look at the following Low Mains Water Pressure & Flow Booster | Stuart Turner Pumps
  11. The Following User Says Thank You to johnf For This Useful Post:
  12. #20
    Riley's Avatar
    Sarf Coast
    6,488
    Seriously get it tested?!?!?!
  13. The Following User Says Thank You to Riley For This Useful Post:
  14. #21
    Jan 2017
    12
    Oh god no, I wouldn't dream of doing it myself lol, me and diy do not go together
  15. #22
    Riley's Avatar
    Sarf Coast
    6,488
    Then enlist a pro. I'm not being short mate. Pumping the mains is doable but as above must be in line with water regs. If your water is worse than before get it tested in the first instance
  16. The Following User Says Thank You to Riley For This Useful Post:
  17. #23
    Jan 2017
    12
    All taken onboard so will get somebody in to check it, many thanks for all the advice.
  18. #24
    Jan 2017
    12
    Ok well I had the water board out today to check my pressure and at both my outside tap and at the tap at the pavement it measured the absolute minimum of 1bar and that was at 2pm when there would be very little usage as most of the estate are at work. The guy rang his manager to ask for advice and was told there must be a problem somewhere as my estate is set at 1.8 bar so we are losing pressure somewhere. He is now going to set up something down the road to monitor it for a week and get somebody out to check some valve somewhere.
    He did say that I was the only person to ever complain which is probably down to the fact that most will still be running off the tank in the loft, my immediate neighbours definitely are as I have asked them. As he was chatting to me a neighbour opposite that I don't know very well actually came out and started complaining about his water pressure being too low and affecting his shower as well.
    With a bit of luck I may get a result out of it although he did say not too expect too much as even if they do get it back up to 1.8 bar then that is still not very good.
  1. No water pressure for the shower
    By Space monkey in forum Plumbing Forum
    Last Post: 22-08-2014, 09:31 PM
  2. no hot water from shower and low pressure
    By can you help... in forum Bathrooms, Showers and Wetrooms
    Last Post: 17-06-2014, 09:28 PM
  3. Replies: 2
    Last Post: 30-12-2011, 10:23 PM
  4. Shower Water Pressure
    By sdowen in forum Bathrooms, Showers and Wetrooms
    Last Post: 27-04-2010, 11:59 PM
  5. Water pressure to shower
    By kuwaiti in forum Bathrooms, Showers and Wetrooms
    Last Post: 10-01-2009, 07:22 PM
