Results 1 to 10 of 10
Plumbing & Plumbers Forum - Shower waste pipe solution
  • 1 Post By 1animal1
Discuss Shower waste pipe solution at UK Plumbers Forums; Morning chaps, I'm wondering if I could trouble you for a bit of advice. I need to drop my 40mm shower waste pipe below the level of the floor as ...
    Aug 2015
    146
    Default Shower waste pipe solution
    Morning chaps, I'm wondering if I could trouble you for a bit of advice. I need to drop my 40mm shower waste pipe below the level of the floor as I do not want any boxing in due to the room being a small en suite. Likelihood is I'll be running with a slate shower base, slightly raised as I'd like access to the waste from what will be the old emersion cupboard behind.
    Problem I have is this. The pipe runs directly to the soil pipe outside, and I can only realistically drop the level of the pipe into the soil pipe, by 20mm, as the WC pipe runs directly beneath. Can I tap into the WC pipe without causing any issues? I assume so but didn't know if there were any problems around back flow etc... Here is a picture of where I could tap into it, however access to drill might also be an issue
    Second problem is running across 5 joists which are near the centre of the house spanning over 10 meters. I've worked out I'll need a notch of 20mm. They are 220mm deep... Not ideal I know but I can't drill centres as I can't get the pipe low enough into the soil stack. Was thinking a couple of pieces of thick steel either side to compensate....
    For info the run is a straight 2m into the outside soil pipe collar currently. What I'm proposing will see a 90 bend dropping into the WC pipe which will then enter the outside soil pipe. That's using 40mm shower waste which will be fed by an unvented system, via a Mira remote mixing valve... Hopefully the 40mm will handle the flow given the minimal amount of bends?
    Many thanks in advance
    Aug 2015
    146
    Default Re: Shower waste pipe solution
    snoopy8888 likes this.
    Aug 2015
    146
    Old picture
    Aug 2015
    146
    Aug 2014
    661
    You can't do the notch, check the regs.
    Aug 2015
    146
    Thank you. I've since found that there is a middle support the correct distance away, so chopping 20mm notches is well within scope being less than 10% of the total depth. I've also decided to run with lowering the soil pipe first and foremost so as not to create flow issues... I'll be running unvented into a new shower unit which I hope will be powerful. I'd rather not upgrade to 50mm pipe if I can help it.
    Riley's Avatar
    Sarf Coast
    6,468
    How long is the run
    Aug 2015
    146
    It's between 2-2.5 metres depending on what shower tray I settle on....
    Riley's Avatar
    Sarf Coast
    6,468
    40mm should be ok get a fast flow waste though
    Aug 2015
    146
    Thanks Riley.... Will do. The run itself is largely straight into the soil pipe, there may be a couple of 90's near the drain itself. Will try to run it as flowing as possible.... Currently sorting out the mess the last fitter has made beneath the floor boards. Some people really have no idea at all. I've one joist with a good 40mm deep diagonal chunk out of it, about a foot long! Loads of wood for the boards to hit :/
  1. McAlpine Shower Waste Traps - 50mm water seal, but 40mm waste pipe
    By BusterG in forum Bathrooms, Showers and Wetrooms
    Last Post: 27-09-2016, 02:09 PM
  2. Shower waste pipe
    By tommy1712 in forum Plumbing Forum
    Last Post: 30-03-2015, 08:47 AM
  3. New bathroom waste solution needed.
    By ben1980 in forum Bathrooms, Showers and Wetrooms
    Last Post: 30-04-2014, 07:34 PM
  4. shower waste pipe
    By andy0678 in forum Bathrooms, Showers and Wetrooms
    Last Post: 30-03-2013, 11:00 PM
  5. Connecting shower waste pipe to horizontal soil pipe underfloor in loft conversion
    By DRichards in forum Bathrooms, Showers and Wetrooms
    Last Post: 05-12-2011, 09:38 PM
