Results 1 to 12 of 15
Plumbing & Plumbers Forum - Old leak from basin waste pipe needs reseal
Discuss Old leak from basin waste pipe needs reseal at UK Plumbers Forums; Looks like a previous sealing job has failed (although not currently damp as the house un-occupied for 4 months) by using some unknown sealant and resulted in previous evidence of ...
    Dec 2016
    Smile Old leak from basin waste pipe needs reseal
    Looks like a previous sealing job has failed (although not currently damp as the house un-occupied for 4 months) by using some unknown sealant and resulted in previous evidence of rotted carpet below this joint & infestation of some form of critters in area (a white powder has been used so maybe ants?).
    Any recommendations chaps what the best cure, sealant, for this please?
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    8,104
    Default Re: Old leak from basin waste pipe needs reseal
    Welcome to the forum.
    looks like a simple "Push Fit" connection which relies on rubber washers to seal. Buy another T piece however the pipe where the sealant is looks undersized unless it is just in the photo.
  3. The Following User Says Thank You to rpm For This Useful Post:
    May 2010
    5,222
    Welcome PB108....looks like a bit of a bodge sealed in with silicon best thing cut it out and remake the whole joint I.e the Tee piece see if you can see a name on the fitting looks like push fit so may be easier than it looks....take that photo to your local merchants best of luck regards Turnpin
  5. The Following User Says Thank You to turnpin For This Useful Post:
  6. #4
    Dec 2016
    Yes it looks like it cold be undersized as said, but also not much room to get out original T piece either as per new photo. Old leak from basin waste pipe needs reseal-dscn6137.jpg.
    Maybe be easier to re-seal?
  7. #5
    Dec 2013
    The center of the universe
    4,269
    By the looks of the pic you need a 40/32 mm pushfit reducer and a new 40mm tee
    joni os likes this.
  8. The Following User Says Thank You to townfanjon For This Useful Post:
  9. #6
    Dec 2016
    Thanks the T piece has stamped on it:
    BS 52 54 PP 2-50mm WP 560.50
    Nothing for the pipe going into it.
    I was thinking some plumbing mait layer for now
  10. #7
    Aug 2014
    673
    Bodge it and scarper! Do it right do it once. Replace the T piece, fit reducer, good for years.
  11. #8
    Mar 2013
    1,487
    Slip coupler needed on horizontal run due to lack of movement. Remake connection with new Tee.
  12. The Following User Says Thank You to joni os For This Useful Post:
  13. #9
    Dec 2016
    All good suggestions, however there is very little room for manoeuvring the T piece out as top joining pipe goes straight up to loft & out to breather on roof and bottom piece dives down below solid floor the side piece goes to the adjoining room's basin.
  14. #10
    Dec 2013
    4,269
    Quote Originally Posted by PB108 View Post
    breather on roof .
    Are you sure ? , we have had a right pro on this one lol
  15. #11
    Aug 2014
    673
    Would the vertical pipe be an air admittance for a WC on a lower floor by any chance? Seen that done before. Simply cut out the pipe either side of the T using
    http://www.ebay.co.uk/itm/42MM-RATCH...-/162178136024
    Then replace section using compression slipcouplers, new pipe, new T etc. Simple enough. Alternatively just call a decent plumber
  16. #12
    Dec 2016
    No it's a bungalow; only soil pipe below & air breather above; side pipe is the basin outflow.
  1. First fixing waste pipe for pedistal basin
    By Mgrant in forum Plumbing Forum
    Last Post: 03-03-2014, 08:38 PM
  2. Cloakroom basin waste into WC soil pipe !
    By Monkey Wrench in forum Plumbing Forum
    Last Post: 02-10-2012, 09:20 PM
  3. Blocked waste pipe from bathroom basin
    By woldig120 in forum Plumbing Forum
    Last Post: 13-09-2012, 04:47 PM
  4. Replies: 8
    Last Post: 05-07-2011, 04:53 PM
  5. Toilet & Basin Waste Pipe Problem !
    Last Post: 07-06-2010, 08:04 AM
