Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Plumbing & Plumbers Forum - Old leak from basin waste pipe needs reseal
Discuss Old leak from basin waste pipe needs reseal at UK Plumbers Forums; Originally Posted by PB108 No it's a bungalow; only soil pipe below & air breather above; side pipe is the basin outflow. Then do as post #11...
  1. #13
    Aug 2014
    661
    Default Old leak from basin waste pipe needs reseal
    Quote Originally Posted by PB108 View Post
    Then do as post #11
  2. #14
    Dec 2016
    Default Re: Old leak from basin waste pipe needs reseal
    Am currently trying ensure the outflow is not blocked by pouring soda crystals in hot water down, my theory is that a blockage built up in past & overflown the joint, as it shouldn't be leaking at all as inclined at decent angle enough.
    The vertical pipe diameter is 53mm where the horizontal in flow is 35mm dia.
  3. #15
    May 2010
    5,163
    Remove the pipe from the trap on the other side of the wall that will allow you to remove the pipe entering the middle of the tee then see if the vent pipe will twist out of the top of the tee if not cut a few inches above the tee ...renew as required adding a slip coupling to the vent pipe then just work back to the trap ......get all your fittings and pipes before attempting this straight forward repair......alternatively get a plumber in....regards Turnpin
  4. The Following User Says Thank You to turnpin For This Useful Post:
  1. First fixing waste pipe for pedistal basin
    By Mgrant in forum Plumbing Forum
    Last Post: 03-03-2014, 08:38 PM
  2. Cloakroom basin waste into WC soil pipe !
    By Monkey Wrench in forum Plumbing Forum
    Last Post: 02-10-2012, 09:20 PM
  3. Blocked waste pipe from bathroom basin
    By woldig120 in forum Plumbing Forum
    Last Post: 13-09-2012, 04:47 PM
  4. Replies: 8
    Last Post: 05-07-2011, 04:53 PM
  5. Toilet & Basin Waste Pipe Problem !
    Last Post: 07-06-2010, 08:04 AM
