Results 1 to 12 of 24
Plumbing & Plumbers Forum - Mira Agile thermostartic mixer isn't that hot
Like Tree3Likes
Discuss Mira Agile thermostartic mixer isn't that hot at UK Plumbers Forums; Hi there I recently had a Mira Agile mixer shower installed and it just doesn't get really hot flow of water from the shower head. It's running from a Combi ...
    Feb 2014
    Default Mira Agile thermostartic mixer isn't that hot
    Hi there
    I recently had a Mira Agile mixer shower installed and it just doesn't get really hot flow of water from the shower head. It's running from a Combi boiler (recently installed and working fine), and the pressures are both equal and strong.
    When I restrict the cold flow into the bathroom, it still doesn't make a difference - still just warm/hot water flow.
    Any advice as to why or a remidy would be amazing.
    Thanks,
    Mitch
    kay-jay's Avatar
    May 2008
    Bolton
    7,226
    Default Re: Mira Agile thermostartic mixer isn't that hot
    Is that the one that has one control dial that turns it on and does temperature as well?
    kay-jay's Avatar
    May 2008
    Bolton
    7,226
    How hot is the water from your taps? Maybe the hw output on the boiler needs tirning up...
    Nov 2012
    whitehaven cumbria
    673
    I take it that you are pushing in the temp safty button to make it hotter. If so have a look in your manual under commissioning you should be able to increase the temp
    failing that it could be a blocked inlet strainer or faulty thermostatic cartridge.
    Feb 2014
    Quote Originally Posted by kay-jay View Post
    It has separate heat and pressure controls.
    Feb 2014
    Taps are red hot. Shower is hot, just not really hot.
    Feb 2014
    Quote Originally Posted by thompsonbrown View Post
    Well the shower is brand new (and as said it is hot, just not really hot, I don't want it scalding, just hot hot! ), so is the boiler. It doesn't have temp safety button for what I know on the Agile.
    kay-jay's Avatar
    May 2008
    Bolton
    7,226
    there isnt a red button on this one i dont think tb.
    just one dial that turns it on and adjusts temp. agree that it could be a blocked filter but would checkhw temp at other outlets first
    Member Paulus's Avatar
    Oct 2010
    Cheshire
    1,084
    It is probably just that the maximum temperature is set too low for your particular requirements. This can be adjusted higher quite simply as can be seen in your User Guide. If you don't have the guide you can download it from the Mira website.
    If we find we cannot help others, the least we can do is to desist from harming them. Dalai Lama.
    Nov 2012
    whitehaven cumbria
    673
    Quote Originally Posted by mitchditch View Post
    If there is no temp overide button then you might find your shower has been factory set at 42 degrees C
    I would contact Mira and see what they say.
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    3,659
    two versions or the agile, one has two controls the other has one
    The instructions show how to increase the maximum temp
    http://www.mirashowers.co.uk/onlinec...user_guide.pdf
    Look under 'Commissioning
    kay-jay and mitchditch like this.
    Regards
    Tom
  12. The Following 2 Users Say Thank You to Plumbstar Tom For This Useful Post:
  13. #12
    Feb 2014
    You sir a legend not a star! Will check this tonight.
    Plumbstar Tom likes this.
  1. mira 723 mixer shower problem
    By wigz in forum Plumbing Forum
    Last Post: 19-03-2011, 12:28 PM
  2. Mira Mixer Shower No Hot Water
    By TDA in forum Plumbing Forum
    Last Post: 10-10-2010, 07:48 PM
  3. Mira 723 mixer problems
    By reggie09 in forum Bathrooms, Showers and Wetrooms
    Last Post: 21-09-2010, 08:39 PM
  4. mira excel shower mixer
    By chelsea in forum Bathrooms, Showers and Wetrooms
    Last Post: 16-07-2008, 01:51 PM
mira agile no hot water
adjust temperature mira agile shower
adjusting the temperature on a mira agile valve
loss of hot water on mira agile
mira excel shower troubleshooting
