Plumbing & Plumbers Forum - Shower triple valve operation
Discuss Shower triple valve operation at UK Plumbers Forums; Hello I am replacing my bathroom and for the most part, the plumbing is within my capabilities. However, I'm planning to use a thermostatic shower valve embedded in the wall. ...
    Mar 2013
    Default Shower triple valve operation
    Hello
    I am replacing my bathroom and for the most part, the plumbing is within my capabilities. However, I'm planning to use a thermostatic shower valve embedded in the wall. I've never used one of these, and I'm struggling to find a good diagram of how they work.
    I think I want a triple valve with diverter, but when I phoned "victoria plum" to ask before buying they said it doesn't do what I thought it did, but couldn't seem to provide any info about what it actually does.
    So, hopefully someone here can help?!
    I will use the shower/bath in one of 4 ways:
    Bath filler only
    Fixed shower only
    Hand shower only
    Fixed and hand shower together
    I imagine (I've never used one) there'd be a handle on the unit which when turned one way will be outlet 1 on full, then turning it will mix with outlet 2 until 2 is on full, then turning further will turn on the diverter. Am I close?
    If I'm wrong, how do they work? Are there any diagrams?
    Cheers
    Cc.
    Member Keefy's Avatar
    Oct 2012
    2,931
    Default Re: Shower triple valve operation
    Not entirely sure I follow, maybe it would be better for you to show us a diagram of how you'd like it to work.
    stoker122's Avatar
    Oct 2010
    Hertfordshire
    497
    I don't think you can get them to mix properly the diverter will only supply a good flow to one outlet.
    Nil desperandum, contages
    www.phpservices.co.uk
    Gas Safe Registered?
    Want gas safety or boiler repair advice?
    The Mods will check out that you're genuine via the gas safe website, so please dont be offended when they ask for your details.
    DIYers, odd job bod's and have a go heroes need not apply.
    kozak1968's Avatar
    Dec 2011
    Belvedere
    903
    The thermostatic mixer has a hot and cold supply to it then on the two outlets you have a lever valve to control on and off. You can install more levers to control more outlets, just tee off on the outlet of the thermostatic mixer. Contact Aqualisa or Grohe showers and their technical department can advise.
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    6,685
    The way it will work on diverter is either on bath tap turn other way on shower does not do both together
    Mar 2013
    Quote Originally Posted by stoker122 View Post
    Quote Originally Posted by Gray0689 View Post
    Yes this is the same as I understand for the diverter part. However I am trying to find out more about a COMBINED thermostatic tripled valve and diverter (I would post a link but the forum wont let me!)
    Quote Originally Posted by kozak1968 View Post
    The thermostatic mixer has a hot and cold supply to it then on the two outlets you have a lever valve to control on and off...
    A twin valve with diverter works as you've described, however I'm looking for infomation about a triple valve with diverter. Thanks, I will give one of the companies you mentioned a call.
    I'll draw a diagram of what I'm looking for as soon as I can get my PC working (posting on my phone).
    In the meantime, does anyone know where I can find a diagram of how they work?
    Thanks for your help.
    Cc.
    17
    Hi Clickclack
    I am trying to do something similar, what kit did you us eventually?
  1. Triple rads
    By Phil in forum Central Heating Forum
    Last Post: 22-09-2013, 04:37 PM
  2. Shower triple valve operation
    By ClickClack in forum Plumbing Forum
    Last Post: 28-03-2013, 11:05 AM
  3. Triple control thermostatic shower valve
    By too hot to hand in forum Plumbing Forum
    Last Post: 26-12-2012, 09:34 PM
  4. Saniflo pump operation
    By trigger25 in forum Plumbing Forum
    Last Post: 30-12-2011, 12:09 AM
  5. Baxi 133 he operation.
    By moogwai in forum Gas Safe Register Forum - Public Forum
    Last Post: 21-12-2011, 05:11 PM
  6. Replies: 5
    Last Post: 16-10-2011, 07:20 PM
  7. Replies: 6
    Last Post: 13-02-2011, 07:10 PM
  8. triple pipe cover
    By swarv in forum Plumbing Forum
    Last Post: 22-11-2008, 07:18 PM
  9. Coated membrane diffusers
    By grafitti001 in forum Plumbing Tools
    Last Post: 27-10-2007, 10:26 AM
triple shower valve with diverter
diverter on triple valve not needed
