Results 1 to 4 of 4
Plumbing & Plumbers Forum - Shower Head
Shower Head
Discuss Shower Head in the Bathrooms, Showers and Wetrooms at Plumbers Forums; I have an electric 9.5 kw shower. It has never been the most powerful pressure wise. I have recently replaced the hose and shower head and it comes out ok, ...
    silverfox
    Default Shower Head
    I have an electric 9.5 kw shower. It has never been the most powerful pressure wise. I have recently replaced the hose and shower head and it comes out ok, but falls rather than sprays???
    Any suggestions please.
    Mick
    May 2009
    7,303
    Default Re: Shower Head
    Just replace shower head for correct one,the one you have probably put on now as holes too big in the shower head,you need a shower head for electric showers,these have smaller holes to allow shower operation with less flow rate
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    2,548
    A 9.5kw should be plenty powerful especially on max setting
    It should most likely have 10mm cabling to it so you could rip it out and pop a 10.4 on there.
    Or as Puddle said buy the correct shower head and hose and have the original performance you had
    Depends on the money you want to spend
    Regards
    Tom
    Feb 2009
    Liverpool
    1,972
    Hmm!
    Have you tried a low loss shower hose with the right shower head. The low lose hose looks the same but the internal diameter is bigger, so you lose less to frictional resistance.
    9.5Kw, should give you a good shower, if site conditions meet specifications. Is the filter blocked? Its usually a sieve like bit of plastic stuck up inside the cold feed. Always worth a check.
  1. Water temp gets hotter when raising shower head
    By Rumpel4skin in forum Bathrooms, Showers and Wetrooms
    Last Post: 14-03-2009, 09:07 AM
  2. Shower Pump Fit to shower pipes only
    By DazJWood in forum Bathrooms, Showers and Wetrooms
    Last Post: 07-03-2009, 07:39 PM
  3. Bathstore Techno Shower Head Problem
    By Techno65 in forum Bathrooms, Showers and Wetrooms
    Last Post: 30-01-2009, 11:20 PM
  4. Sudden problem with low pressure at shower head and live with four women
    By kevofcov in forum Bathrooms, Showers and Wetrooms
    Last Post: 15-12-2008, 11:31 AM
  5. Poor flow from shower head!!
    By dsinclair999 in forum Bathrooms, Showers and Wetrooms
    Last Post: 05-10-2008, 11:42 PM
Whats inside an electric shower-head
