Results 1 to 15 of 19
Plumbing & Plumbers Forum - Shower pumps
Shower pumps
Discuss Shower pumps in the Bathrooms, Showers and Wetrooms at Plumbers Forums; Hi I fitted a new mixer shower pump in Feb 2012 to a gravity fed mixer shower. The old pump had worn out, it was a Triton T550. I called ...-
07-08-2012 #1Steady Plumbing Forum Contributor
- Apr 2009
- 153
- 84
- Thanked 1 Time in 1 Post
Shower pumps
Hi
I fitted a new mixer shower pump in Feb 2012 to a gravity fed mixer shower. The old pump had worn out, it was a Triton T550. I called triton and they suggested I changed it to the Triton T550i which pumps up to 1.2 bar at 16 litres a minute max.
Had a call a few days ago from the client to say after 4 minutes in the shower the cold stops working and only hot is coming out of the shower.
After investigating I noticed that the feeder tank in the loft is emptying quicker than it is refilling hence the cold water is running out.
I have checked with the water board and they say that the pressure coming from the road is within there acceptable limits but the flow is only 15 liters a minute.
I have tried turning down the speed of the pump but this just delays the problem
The other idea I thought would be to increase the tank size, however the loft opening is very slim and there is no way of getting another tank in the loft.
The only other thing I can think of is getting a less powerful pump?
Can anyone suggest one?? or other ideas
Many thanks
Paul
07-08-2012 #2Plumbers Arms member
- Feb 2011
- The Land Of The Prince Bishops
- 7,217
- 284
- Thanked 691 Times in 681 Posts
Re: Shower pumps
Have a look at a coffin tank, may be able to get it in.
The Following User Says Thank You to SimonG For This Useful Post:
Paul Cockhill (13-08-2012)
07-08-2012 #3Plumbers Arms member
- Jan 2012
- Essex
- 3,198
- 80
Re: Shower pumps
You could fit a low pressure seating into the ball valve or fit a 3/4 ball valve into the cold water tank.
The Following User Says Thank You to mountainman For This Useful Post:
07-08-2012 #4UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
Re: Shower pumps
or even two ballvalves?a round 50/70 tank will go through a hatch thats 600mm measured diagonal so a 25/30 will go through any hatch a man can get through
The Following User Says Thank You to stevetheplumber For This Useful Post:
09-08-2012 #5Plumbing Forum Contributor
- Jan 2011
- 96
- Thanked 22 Times in 22 Posts
Re: Shower pumps
Any idea what size cistern is fitted in the roof?
13-08-2012 #6Steady Plumbing Forum Contributor
- Apr 2009
- 153
- 84
Re: Shower pumps
Hi
stupidly did not measure it but it is about 3ft in length by 1.5 ft wide by1.5ft deep at a guess
13-08-2012 #7Super Plumbing Forum Contributor
- Jun 2012
- 1,450
- 12
- Thanked 125 Times in 120 Posts
Re: Shower pumps
How about doubling the capacity by putting a similar sized tank alongside linked to the existing one?
******************** http://www.comodo.com/home/browsers-...rs/browser.php ********************
14-08-2012 #8Plumbers Arms member
- Jun 2012
- London/Kent
- 1,713
- 102
- Thanked 183 Times in 179 Posts
Re: Shower pumps
Go with the 2 x 1/2" float valves, it worked for me & it's cheap (only thing to watch is the dynamic mains pressure will fall while pump is in use)
14-08-2012 #9Super Plumbing Forum Contributor
- Jun 2012
- 1,450
- 12
Re: Shower pumps
So if the main delivers 15 litres a minute, and the pump displaces 16 litres a minute, two valves will increase the overall delivery? How does that work?
14-08-2012 #10Plumbers Arms member
- Jun 2012
- London/Kent
- 1,713
- 102
Re: Shower pumps
Does the mains deliver only 15L/M, where was this tested ?? The main restriction is the seating which on a 1/2" H/P float valve is about 5mm dia (not 15mm pipe connection) So flow rate is restricted, by installing 2 you can increase the area, reducing the restriction & increasing the flow rate. If you increase the flow rate (sometimes called recovery) you can decrease the storage. In this case get more out of the cistern before the water runs out due to the use of the shower booster.
Of course you could always install a shower flow restrictor to limit the flow to say 12L/M which will still give a good shower.
14-08-2012 #11fuzzyGuest
Re: Shower pumps
if it refils at 15l/m and shower works at 16l/m then the cistern is losing 1 l/m. how long are thier showers if this is emptying the cistern?
14-08-2012 #12Super Plumbing Forum Contributor
- Jun 2012
- 1,450
- 12
Re: Shower pumps
According to the sales data, the Triton T550i displaces 11.5 litres per minute?
Is the current valve working as it should be?Last edited by petercj; 14-08-2012 at 11:02 AM.
14-08-2012 #13Plumbers Arms member
- Jun 2012
- London/Kent
- 1,713
- 102
14-08-2012 #14Super Plumbing Forum Contributor
- Jun 2012
- 1,450
- 12
Re: Shower pumps
I don't go in for name calling chris, and I know from your posts that you know your stuff.
You were really quick off the mark with your reply, because as soon as I re-read my original post I changed it through 'edit' re checking the current valve in relation to the 11.5 displacement figure given for the T550i, i.e. maybe the current valve is not passing as it should.******************** http://www.comodo.com/home/browsers-...rs/browser.php ********************
The Following User Says Thank You to petercj For This Useful Post:
chris watkins (14-08-2012)
20-08-2012 #15Steady Plumbing Forum Contributor
- Apr 2009
- 153
- 84
Re: Shower pumps
Thanks guys for all you comments. The client is a good friend of mine at he seems happy at the moment as all works well if he has showers for 4 minutes or less.
One question
If I teed off the supply coming into the cistern, so I had two supplies coming into the same cistern would that make a significant difference, or would it be better to put another cistern in the loft space and connect the two
thanks
Paul
Cold whether and shower pumps
By srmans in forum Plumbing ForumReplies: 2Last Post: 31-01-2012, 04:52 PM -
techflow shower pumps
By unguided1 in forum Bathrooms, Showers and WetroomsReplies: 8Last Post: 20-03-2011, 09:50 AM -
Shower Pumps
By MickBrown in forum Plumbing ForumReplies: 1Last Post: 06-01-2011, 03:22 PM -
Quite shower pumps
By andyb in forum Bathrooms, Showers and WetroomsReplies: 4Last Post: 05-10-2009, 08:27 AM -
shower pumps
By barronbathrooms in forum Bathrooms, Showers and WetroomsReplies: 8Last Post: 08-09-2009, 08:56 PM
cylinder flange
6 Minutes Ago in Plumbing Forum
