Results 1 to 4 of 4
Plumbing & Plumbers Forum - Mira Sport troubleshooting advice
Discuss Mira Sport troubleshooting advice in the Bathrooms, Showers and Wetrooms at Plumbers Forums; Hi, If anyone can help me determine what's wrong with my Mira Sport shower (92-98 model), that would be brilliant. Previously it's worked fine with more than ample pressure from ...-
27-07-2012 #1New to Plumbing Forum
- Jul 2012
- 4
Previously it's worked fine with more than ample pressure from shower head. Last night it stopped working. There is plenty of water flow and pressure from the cold tap in the bathroom.
Symptons are as follows:-
Set to Stop - Power light On, no flow of water, Low Pressure light Off.
Set to Cool - Power light On, water dribbles from shower head (200ml/minute), Low Pressure light Off.
Set to Low/High - Power Light On, water dribbles from shower head (200ml/minute), Low Pressure light On.
Tried removing shower head pipe from shower unit, water just dribbles out at the same rate.
The Mira website (which I guess is for the later version of the Sport) suggests a water pressure problem, but it seems odd to me that it would go from no problem to virtually nothing so quickly.
If anyone can offer suggestions on what the problem might be and how I can fix it, that would be excellent.
Thanks,
Stuart.
27-07-2012 #2Moderator
- Feb 2010
- Alloa, Scotland
- 7,068
- 745
- Thanked 672 Times in 573 Posts
Re: Mira Sport troubleshooting advice
Doubt if it's a water pressure problem if your water pressure has remain unchanged. Was the water turned off at any time recently?
If the shower is needing parts, it would be better to buy a new shower due to the age of your existing one.
Bathroom Design & Installation Specialists.
Over 34 years experience.
Rated People 5 Star Rating.
BY THE WAY I'M NOT COMMERCIAL. A flexible hose, gets up ma nose.
28-07-2012 #3Plumbers Arms member
- Feb 2011
- The Land Of The Prince Bishops
- 7,210
- 284
- Thanked 691 Times in 681 Posts
Check the filter first, if ok scrap it and get a new one.
28-07-2012 #4New to Plumbing Forum
- Jul 2012
- 4
The water supply hasn't been turned off at all recently.
I can check the filter, but given it was fine before I'm guessing that would be a long shot. Regarding your comments about replacing rather than repairing, that makes sense.
Thanks for taking the time to reply.
Mira Sport 7.5 kw
By colkat in forum Bathrooms, Showers and WetroomsReplies: 23Last Post: 12-12-2011, 09:10 PM -
MIra Sport Shower
By morseman in forum Bathrooms, Showers and WetroomsReplies: 4Last Post: 05-11-2011, 09:55 AM -
mira sport
By apcdave in forum Bathrooms, Showers and WetroomsReplies: 9Last Post: 30-05-2010, 08:40 PM -
mira sport shower
By adrianfs1 in forum Bathrooms, Showers and WetroomsReplies: 5Last Post: 14-05-2010, 01:51 PM -
mira sport (problem)
By jampot in forum Bathrooms, Showers and WetroomsReplies: 3Last Post: 15-12-2009, 02:45 PM
WHOAHO...time to give it all up
