Results 1 to 4 of 4
Plumbing & Plumbers Forum - Pump pulsing
Pump pulsing
Discuss Pump pulsing in the Bathrooms, Showers and Wetrooms at Plumbers Forums; I have a customer with a set of stuart turner 3bar monsoon pumps. One of the pumps is fairly new and problem free. the other however has developed a problem. ...-
21-06-2012 #1Steady Plumbing Forum Contributor
- Mar 2010
- s****horpe
- 129
- 8
- Thanked 5 Times in 5 Posts
Pump pulsing
I have a customer with a set of stuart turner 3bar monsoon pumps. One of the pumps is fairly new and problem free. the other however has developed a problem. ! The pump itself is via an essex flange flows down to pump, and cold via cold storage to pump, not a problem with pipework but detailing as much as poss !! The pump feeds 2 showers and works fine ondemand, full pressure and off when not inuse, but since last week has started to pulse when any other (hot) tap is used in the house, even though the tap is not part of the pump circuit !!
For example kitchen tap switched on, then off, immideately when tap is turned off the pump clicks on then off.
Now im not sure if for some reason it is detecting some flow movement in the cylinder, which to me indicateds maybe a faulty flow switch ???? but i have never fitted one of these pumps or have had to deal with one before. Has anybody had a similar problem, if so, what , where , how, and what was done ?? is the flow switch a replaceable part ?
21-06-2012 #2Plumbing Forum Contributor
- Mar 2010
- 93
- 5
- Thanked 16 Times in 14 Posts
Re: Pump pulsing
I've got a Stuart Turner pump at home. We get the occasional airlock, and this seems to cause the pump to pulse whenever another tap (usually hot) is used elsewhere in the house. Problem persists until the last bit of air is out then all is fine again.
21-06-2012 #3Plumbers Arms member
- Jan 2012
- Essex
- 3,201
- 80
If the pump is positive head then as said it could be a bit of air or maybe the flow switch is dirty.
If it's negative head then the non-return valve on the hot water side could be letting by.Proud to be 'Part P', the world is now my mollusc!
22-06-2012 #4Steady Plumbing Forum Contributor
- Mar 2010
- s****horpe
- 129
- 8
Re: Pump pulsing
hi its a positive head pump. Pipework is all angled few degrees down to point of entry on pump, so surely air would find its way back to cylinder !! Stuart turner tech team said oh its the cylinder not refilling quick enough and movement of water in tank switching pump on, yet the other pump next to it is fine, he said to clean / check the flow switch it would need dismantelling ?? Not even sure what to tell the customer ?? well i would like to spend 2 hours stripping the pump then rebuild and it still doesnt work so paqy me or get a new pump or just leave it !!
Pulsing shower pump
By Keen amateur in forum Bathrooms, Showers and WetroomsReplies: 32Last Post: 27-04-2011, 08:16 AM -
new shower pump pulsing
By welly2510 in forum Bathrooms, Showers and WetroomsReplies: 2Last Post: 13-04-2011, 02:18 PM -
shower pump pulsing on and off
By bobjayes in forum Plumbing ForumReplies: 3Last Post: 02-09-2010, 06:42 PM -
Shower pump pulsing!
By njmorrison in forum Bathrooms, Showers and WetroomsReplies: 8Last Post: 11-10-2009, 01:38 AM -
By njmorrison in forum Plumbing ForumReplies: 0Last Post: 08-10-2009, 07:17 PM
My work is drying up???? Help...
4 Minutes Ago in Plumbing Forum
