Plumbing & Plumbers Forum - Replacing electric showers with thermostatic mains showers
Discuss Replacing electric showers with thermostatic mains showers in the Bathrooms, Showers and Wetrooms at Plumbers Forums; Hello We run a small guesthouse which has nine good (mostly Mira Flex) thermostatic electric showers. We are planning on installing a new boiler which will provide more than enough ...-
29-05-2012 #1New to Plumbing Forum
- Dec 2011
- Spean Bridge, Inverness-shire, Scotland
- 11
Hello
We are planning on installing a new boiler which will provide more than enough hot water for mains fed showers. As these would be cheaper to run and be more powerful we are thinking through whether it would be practical to change them all over.
The main draw back is that we cannot afford to re-tile the shower enclosures at the moment and removing the electric shower boxes is bound to reveal broken tiles, screw holes etc.
Is there some way of hiding these defects with a fascia of some sort? Is this a common problem? Am I better sticking with what we have?
Peter
29-05-2012 #2
29-05-2012 #3Plumbers Arms member
- Oct 2010
- Powys
- 302
- 22
- Thanked 15 Times in 13 Posts
Sounds like replacing them all would be prohibitively expensive. I have not come across a product that would cover the hole left by removing the electric showers. Equally unless you are going to have exposed pipes to new mixer showers, the new pipe work would need to concealed = serious damage and tiling.
Would make sense if you changed as and when you refurbished each shower room, as I am sure you will have to do over time.
Sent from my iPad using Tapatalk HD
29-05-2012 #4New to Plumbing Forum
- Dec 2011
- 11
Re: Replacing electric showers with thermostatic mains showers
thank you
29-05-2012 #5New to Plumbing Forum
- Dec 2011
- 11
29-05-2012 #6Plumbers Arms member
- Oct 2010
- Powys
- 302
- 22
Hi, checked out your website, very nice - may come and visit sometime
30-05-2012 #7New to Plumbing Forum
- Dec 2011
- 11
Electric showers???
By Zorro in forum Bathrooms, Showers and WetroomsReplies: 10Last Post: 26-07-2011, 09:48 PM -
Non-thermostatic showers
By WaterTight in forum Plumbing ForumReplies: 11Last Post: 14-05-2011, 11:29 PM -
thermostatic mixer showers
By mark_mc in forum Plumbing ForumReplies: 7Last Post: 02-02-2011, 11:39 PM -
Replacing showers.....
By Dan in forum Bathrooms, Showers and WetroomsReplies: 5Last Post: 24-08-2008, 09:20 PM
Best way to remove solder ready...
1 Minute Ago in Fittings & Pipes
