Plumbing & Plumbers Forum - Shower Pump, Digital pumped Shower, Venturi Valve, Electric?? Im so confusedd!!
Discuss Shower Pump, Digital pumped Shower, Venturi Valve, Electric?? Im so confusedd!! in the Bathrooms, Showers and Wetrooms at Plumbers Forums; Hi, Im new here and have been reading lots of excellent advice from this site.. Thanks guys! I have a dilemma about what type of shower system to install and ...-
12-02-2011 #1New to Plumbing Forum
- Feb 2011
- 3
I have a dilemma about what type of shower system to install and was wondering if someone could give me some advice?
Ive recently purchased a 2 bedroom first floor maisonette and renovating it with plans to rent it out for a year or two.
Im in the middle of doing the Bathroom, and need to work out what shower is best, ive been thinking about and researching it for weeks and still cant decide... its doing my head in!
The flat has a gravity system... hot water tank in the airing cupboard, with a 20 gallon cold water storage tank just above it ( in the same cupboard, not in the loft - which i find strange but anyway..)
The hot and cold gravity pressures arent very good at all.
I have measured the mains pressure and it is 2.5bar, but im not sure if the flow rate is very good.
Basically i want to have a good and powerful shower and was set on installing a 1.5bar pump and thermostatic shower valve... then the more i researched it, the more confused i got, as people say the shower pumps are really noisy - i want to keep the disturbance for the old lady downstairs to a minimum. - she can be a real pain in the ***
I heard the digital pumped showers are another option, but i dont know how powerful these would be? is anyone able to give their comparisons between a pumped digital shower and 1.5/2.0 bar shower pump?
I was going to order a Trevi Boost Venturi shower but then decided against it as i heard theyre very sensitive to limescale and debris ( the flats in a heavy limscale area) and i want to keep call outs from tenants to a minimum
Other option i was looking at was an electric shower, but i dont think that would give me the power showering experience i would like.
If the performance from a pump is worth overlooking the noise, im willing to do that, and i understand i will probably have to upgrade the capacity of the cold water tank which i dont mind doing if it is worth it?
I guess the question comes down to how good/powerful a digital pumped shower will be compared to an old fashioned pumped thermostatic shower?
Ive been looking at the Mira Magna UV pumped and Aqualisa visage showers. Has anyone had any experience with these and also how much power and noise do i get from something like a Salamander CT50.
Any advice and experiences will be really appreciated... and sorry for the long winded post!!
Cheers!
12-02-2011 #2uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,567
- 836
- Thanked 1,284 Times in 1,225 Posts
Re: Shower Pump, Digital pumped Shower, Venturi Valve, Electric?? Im so confusedd!!
shower pumps you want then? Google or speak to Stuart turner the best pumps you can buy or speak to a good plumber
GASMAN
12-02-2011 #3New to Plumbing Forum
- Feb 2011
- 3
Have you had any experience with digital pumped showers?
12-02-2011 #4uɐɯ sɐƃ moderator
- Jan 2010
- 13,567
- 836
no...........anything digital is crap IMHO,get a pump,if applicable and if it is look at a grohe therm 1000 shower,problem solved
GASMAN
12-02-2011 #5UK Plumbersforums Trusted Advisor.
- Jun 2010
- Northern Ireland
- 4,873
- 76
- Thanked 447 Times in 434 Posts
13-02-2011 #6New to Plumbing Forum
- Feb 2011
- 3
Thanks Gray0689. Whats the power and flow rate like on them? and how noisy are the pumps on these?
13-02-2011 #7UK Plumbersforums Trusted Advisor.
- Jun 2010
- Northern Ireland
- 4,873
- 76
shower valve and pump problem
By bingobill in forum Plumbing ForumReplies: 2Last Post: 11-11-2010, 07:29 PM -
Pump for electric shower
By biker9999 in forum Bathrooms, Showers and WetroomsReplies: 5Last Post: 20-09-2010, 08:34 AM -
Digital shower + bath filler + hand shower
By tempsc in forum Bathrooms, Showers and WetroomsReplies: 7Last Post: 26-08-2010, 11:40 PM -
thermostatic valve/ shower pump problem
By jimmy73 in forum Plumbing ForumReplies: 4Last Post: 15-12-2009, 08:36 AM -
Bath & Shower Valve and Pump and issues
By darrenh in forum Plumbing ForumReplies: 6Last Post: 18-02-2008, 01:16 PM
4 Minutes Ago in Plumbing Tools
