Plumbing & Plumbers Forum - Meynell Safemix V6 servicing
Discuss Meynell Safemix V6 servicing in the Bathrooms, Showers and Wetrooms at Plumbers Forums; Hi, Got a leaking meynell shower mixer valve (Concealed/recessed.) Got a seal kit, silicon grease etc. ready to disassemble and repair. When I turn off the mains water valve, where ...-
22-01-2011 #1New to Plumbing Forum
- Mar 2010
- 9
When I turn off the mains water valve, where is the best faucet to relieve the pressure? The shower valve itself? or the bath tub? or bathroom sink? does it matter to relieve pressure using the hot or cold tap? Keep the shower valve "open" when switching back on mains or clear the air block with kitchen/bathroom sink first?
Hot water supplied by a Gledhill Pulsacoil III. When the mains is off, will the hot water still be able to "escape" to the shower valve because it is driven by a Grundfos pump? Anytime I turn on the hot water, the pump runs to drive the hot water to the tap/shower. Need to turn this pump off too before going to remove the shower valve?
First time doing this - but determined.
any more pearls of wisdom on this appreciated.
thanks
Bert
22-01-2011 #2New to Plumbing Forum
- Jan 2011
- 13
- Thanked 5 Times in 5 Posts
Re: Meynell Safemix V6 servicing
I would recommend draining it from the lowest point (kitchen sink maybe?) as water obviously drops. Let all the water drain and then opem the shower to let all air in and release any further water. Make sure you turn the pump off as any air getting into it may cause it run dry and burn out the pump. Once drained do your necessary repair and recommission. make sure you keep the pump turned off and refill the system starting from downstairs and working upwards. any hot water should still run through the pump but just not with the pressure you had before. Fill the shower valve by pulling water through it and then you should be able to turn your pump back on. make sure your boiler is also turned off whilst doing this as this may also burn out if no water is running through it. It's up to you if you want to leave the shower turned on when you turn the water back on but i generally turn everything off before recommissioning and bleed each tap seperately.
Hope this helps and not too confusing for you as reading it back it appears to be lol
The Following User Says Thank You to D.W.Bathrooms For This Useful Post:
bertle (22-01-2011)
22-01-2011 #3New to Plumbing Forum
- Mar 2010
- 9
Thanks for the great advice, dwbathrrooms.
I get the bit about the lowest water point to relieve water pressure. In my case, this is the bath tub. I dont have upstairs/downstairs - I live in a flat. In terms of refilling system, I am a little confused - Do you mean turn on the lowest faucets first? Then work up in terms of each faucet's height? And turn the shower/sink/basins onto hot first to get some water back into pump before it goes on again..?
thanks
bert
22-01-2011 #4New to Plumbing Forum
- Jan 2011
- 13
Sorry my mistake in thinking you may of had upstairs/downstairs. best thing to do is just pull water through all your outlets (taps) etc. both hot and cold but do this without the pump being on. If you run the pump and no water has gone through it then it may run dry and burn out. So basically turn it off before you drain down all the water and leave it turned off until you have pulled water through everywhere.
Hope it all goes ok for you, any more advice needed jus p.m me
bertle (23-01-2011)
23-01-2011 #5New to Plumbing Forum
- Mar 2010
- 9
thanks dw bathrooms. I get it 100%.
best,
BErt
Boiler Servicing
By OFTEC in forum Plumbing ForumReplies: 36Last Post: 07-05-2011, 05:54 PM -
Servicing Discontinued Boilers
By tipintim in forum Central Heating ForumReplies: 6Last Post: 25-11-2010, 09:47 PM -
Servicing prices
By bikerbas in forum Gas Safe Register Forum - Public ForumReplies: 13Last Post: 23-08-2010, 03:07 PM -
Kane FGA servicing
By WHPES in forum Central Heating ForumReplies: 0Last Post: 14-12-2009, 10:23 AM -
British Gas servicing
By helpsy in forum Central Heating ForumReplies: 6Last Post: 28-09-2009, 08:53 PM
Hi All
1 Minute Ago in New Member Introductions
