Plumbing & Plumbers Forum - drilling holes for shower valves, mixers etc
Discuss drilling holes for shower valves, mixers etc in the Bathrooms, Showers and Wetrooms at Plumbers Forums; We provide a drilling service for hard tiles if you need perfect holes in very hard tiles. If you have a mixer feed or shower valve at either a specific ...-
30-09-2008 #1** UKPF Sponsor **
- Sep 2008
- Hoddesdon
- 331
- 19
- Thanked 13 Times in 10 Posts
If you have a mixer feed or shower valve at either a specific size or it needs to be custom cut then we can provide holes.
Either on our own drill press or we come to you.
Drilling hard porcelain wall tiles with 365 drills diamond holesaws granite cutting marble floors
Perfect hole placed into a C5 industrial grade porcelain tile
01-10-2008 #2Plumbers Arms member
- Jan 2008
- leeds
- 718
- 16
- Thanked 13 Times in 13 Posts
Re: drilling holes for shower valves, mixers etc
Mate looked high and low for a bit that can do 160 mm perfect hole for a mira silver mixer to fit through do you do anything this big ? how does everyone else get these holes 150 - 160 mm bang in the middle of a 240mmx 240mm ceramic... prob should put this on tilers forum though seems relevant enough. I ended up using an angle grinder though was obviously not the easiest way???
06-10-2008 #3** UKPF Sponsor **
- Sep 2008
- Hoddesdon
- 331
- 19
The max is 125mm BUT we are able to use the 125mm to open out by doing multiple cuts.
The results are just not so elegant but functional.
At 365Drills we provide an inhouse tile drilling service for large holes into large tiles. Same day collection and return within the M25
what is it ?
58 Minutes Ago in General Off-Topic Chat
